configure port shared-packet-buffer
configure port port_list shared-packet-buffer [percent | default]
Description
Configures the maximum amount of the shared packet buffer to be used by the specified ports.
Syntax Description
port_list Specifies a list of ports or slots and ports.
percent Specifies the maximum portion of the shared packet buffer to allot. The range is 0 to 100 percent.
On some platforms, the hardware provides a limited number of settings. In these cases, ranges of percentage values achieve the same setting.
You can view the configured percentage value using the show ports port-list info detail command.
You can view the effect of this command using the show ports port-list buffer command.
Default
None.
Usage Guidelines
It is possible to overcommit the shared packet buffer using this command.
The following command sets the shared packet buffer for port 1:1 to 50%:
configure port 1:1 shared-packet-buffer 50
This command was first available in ExtremeXOS 12.5.
Platform Availability
